With 1920 x 1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF5537MSC-B1AG delivers seamless and accurate touch response. Featuring an AMVA3 Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands 60950-1 drop ball test, making it suitable for demanding environments. The open frame ProLite TF5537MSC-B1AG is the ideal solution for Interactive digital signage, instore retail, kiosks, gaming and interactive presentations.
- iiyama ProLite TF5537MSC-B1AG 55" LED-backlit LCD display
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 55"
- Black
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- AMV3
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, clamper
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 110 Watt
- Power Consumption (On mode)
- 115 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 168 kWh
- Dimensions (WxDxH) - without stand
- 129.45 cm x 8.9 cm x 76.55 cm
- 47 kg
- Product Type
- Energy Class
- Class B
- 110 Watt
- 115 W
- 168 kWh
- Diagonal Class
- 55"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Dimensions
- Without stand
- 129.45 cm
- 8.9 cm
- 76.55 cm
- 47 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMV3
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.4833mm x 0.4833mm
- Touchpoints Qty
- 12
- Response Time
- 6.5 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 14 Watt
- Speakers
- 2 x main channel speaker - 7 Watt
- Connector Type
- DVI-D input , VGA input , USB , HDMI input , Serial output
- Clamper
- Cables Included
- VGA cable , DVI cable , USB cable
- DDC-2B, VESA DPMS, TUV Bauart, IPX1
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
