iiyama 55" LED P-Cap 12 Point Touch Display 1920 x 1080 Black
Quicklinx: BVPGWS00 Mfr#: TF5537MSC-B1AG
  • 1080p
With 1920 x 1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF5537MSC-B1AG delivers seamless and accurate touch response. Featuring an AMVA3 Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands 60950-1 drop ball test, making it suitable for demanding environments. The open frame ProLite TF5537MSC-B1AG is the ideal solution for Interactive digital signage, instore retail, kiosks, gaming and interactive presentations.
iiyama ProLite TF5537MSC-B1AG 55" LED-backlit LCD display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
AMV3
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, clamper
Voltage
Energy Class
Class B
110 Watt
Power Consumption (On mode)
115 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
168 kWh
129.45 cm x 8.9 cm x 76.55 cm
47 kg
Energy Class
Class B
110 Watt
115 W
168 kWh
Diagonal Class
55"
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Face-up Mode
Dimensions
Without stand
129.45 cm
8.9 cm
76.55 cm
47 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4833mm x 0.4833mm
Touchpoints Qty
12
Response Time
6.5 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - 7 Watt
Connector Type
DVI-D input , VGA input , USB , HDMI input , Serial output
Clamper
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Input Voltage
0.5 Watt
