Incorporating the improved infrared 10 point touch feature along with supreme panel color performance, this display offers the optimum result for a truly multi-user interactive experience. With the ability to handle up to 10 individual touch points, the display offers an exceptional capacity within retail, education, training, corporate and B2B markets. Its characteristics include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. It also features an ambient light sensor, delivering optimal picture quality with the added benefit of saving on power. Incorporating protection glass and AG-coating, the display can handle harsh environments from the classroom to public domain retail installation. Landscape- and portrait-friendly, a perfect solution for interactive digital signage.
- iiyama ProLite TH5564MIS-B3AG 55" Class (54.6" viewable) LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 120Hz Refresh Rate
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- AMV3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, pen stylus, sticker
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 150 Watt
- Power Consumption (On mode)
- 117 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 171 kWh
- Dimensions (WxDxH) - without stand
- 127.1 cm x 11.05 cm x 74.2 cm
- 43.1 kg
- Product Type
- Energy Class
- Class B
- 150 Watt
- 117 W
- 171 kWh
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Film Mode, portrait mode, landscape mode, Picture mode
- Protection
- Protection glass
- Dimensions
- Without stand
- 127.1 cm
- 11.05 cm
- 74.2 cm
- 43.1 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMV3
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Image Contrast Ratio
- 4000:1
- Brightness
- 445 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 6.5 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Infrared multitouch technology, Noise Reduction
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x main channel speaker - 12 Watt
- Connector Type
- LAN , Serial input , Serial output , DisplayPort , DVI-D input , DVI-D output , 2 x HDMI , Component video input , S-Video input , Composite video input , Composite video output , Audio output , Audio input , Audio input , VGA input , VGA output , Speakers output , USB
- Pen stylus, sticker
- Cables Included
- VGA cable , DVI cable , USB cable
- DDC-2B, VESA DPMS, CB, WEEE, TUV Bauart, ERP, EAC
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- 0 °C
- 40 °C
- 0 - 85% (non-condensing)
