Incorporating the InfraRed 10 point touch feature along with our supreme panel colour performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting colour reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. Features include PIP and PBP perfect for Video Conferencing or handing multi-input content in many environments. Landscape and Portrait friendly, the display can be mounted according to the application for true impact in Interactive Digital Signage and with Protection Glass the display can handle harshest environments from the Classroom to Public Domain Retail installation.
Touch technology - infrared
The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover, the display characteristics remain virtually unaffected by the touch functionality. -
AMVA3 technology
AMVA3 technology offers higher contrast, darker blacks, and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
- iiyama ProLite TH4664MIS-B2AG 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- AMV3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 100/240 V (50/60 Hz)
- Energy Class
- Class B
- 136 Watt
- Power Consumption (On mode)
- 97.7 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 107.95 cm x 10 cm x 63.4 cm
- 28.9 kg
- Product Type
- Energy Class
- Class B
- 136 Watt
- 97.7 W
- Diagonal Class
- 46"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 107.95 cm
- 10 cm
- 63.4 cm
- 28.9 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMV3
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53025 x 0.53025mm
- Touchpoints Qty
- 10
- Response Time
- 6.5 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
- Infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x main channel speaker - 12 Watt
- Connector Type
- LAN , Serial input , Serial output , DisplayPort , DVI-D input , HDMI , Component video input , S-Video input , Composite video input , Composite video output , Audio output , 2 x audio input , Audio input , VGA input , VGA output , Speakers output , USB
- Cables Included
- VGA cable , DVI cable , USB cable
- Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
