Your basket is empty
iiyama 46" Black LED Large Format Display 1920 x 1080 18/7 500 cd
Quicklinx: C7NTWS00 Mfr#: TH4664MIS-B2AG
Select:
  • 1080p (Full HD)
Incorporating the InfraRed 10 point touch feature along with our supreme panel colour performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting colour reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. Features include PIP and PBP perfect for Video Conferencing or handing multi-input content in many environments. Landscape and Portrait friendly, the display can be mounted according to the application for true impact in Interactive Digital Signage and with Protection Glass the display can handle harshest environments from the Classroom to Public Domain Retail installation.
Iiyama ProLite TH4664MIS-B2AG 46" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 100/240 V (50/60 Hz)
Energy Class
Class B
136 Watt
Power Consumption (On mode)
97.7 W
107.95 cm x 10 cm x 63.4 cm
28.9 kg
Energy Class
Class B
136 Watt
97.7 W
Diagonal Class
46"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
107.95 cm
10 cm
63.4 cm
28.9 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Touchpoints Qty
10
Response Time
6.5 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x main channel speaker - built-in - 12 Watt
Connector Type
Network , Serial input , Serial output , DisplayPort , DVI-D input , HDMI , Component video input , S-Video input , Composite video input , Composite video output , Audio output , 2 x audio input , Audio input , VGA input , VGA output , Speakers output , USB
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
