With 1920x1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF4237MSC-B1AG delivers seamless and accurate touch response. Featuring an IPS Direct LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the display comes with a rugged bezel making it suitable for demanding environments.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Open frame
Open frame monitors come equipped with external mounting brackets making them an ideal solution for kiosk integrators. -
AG coating
The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
- iiyama ProLite TF4237MSC-B1AG 42" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, clamper
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 100 Watt
- Power Consumption (On mode)
- 68 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 99 kWh
- Dimensions (WxDxH) - without stand
- 97.55 cm x 8.8 cm x 57.5 cm
- 24 kg
- Product Type
- Energy Class
- Class B
- 100 Watt
- 68 W
- 99 kWh
- Diagonal Class
- 42"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Dimensions
- Without stand
- 97.55 cm
- 8.8 cm
- 57.5 cm
- 24 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Coating
- 7H Hard
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.4833mm x 0.4833mm
- Touchpoints Qty
- 12
- Response Time
- 6 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 14 Watt
- Speakers
- 2 x main channel speaker - 7 Watt
- Connector Type
- DVI-D input , VGA input , Audio line-in , Audio line-out , Serial input , Serial output , USB , Remote control
- Clamper
- Cables Included
- VGA cable , DVI cable , USB cable
- DDC-2B, VESA DPMS, TUV Bauart, IPX1
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- No
