Your basket is empty
Iiyama 27" LED 1920x1080 VGA DVI HDMI 4 x USB Height Adj
Quicklinx: 87ZMWS00 Mfr#: B2780HSU-B1
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 2ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15)
More than 50 in stock
£179.40 ex VAT
£215.28 inc VAT
The ProLite XB2780HSU is a 27'‘, eco friendly LED monitor featuring MVA Panel technology. This sophisticated technology provides wide viewing angles and offers superb color performance including superior black and white display. A 5000:1 Native Contrast Ratio means the ProLite XB2780HSU is ideal for Photographic Design and Web Design. Featuring Full HD 1920 x 1080 resolution with VGA, DVI, HDMI signal connectivity and a 4 port USB-HUB, this screen is compatible with a wide range of systems and applications, making it an excellent choice for Universities, Corporate, Financial and Design Markets. The ergonomic stand offers 11cm height adjustment, pivot and swivel.
Iiyama ProLite B2780HSU - LED monitor - 27"
Aspect Ratio
Widescreen
Native Resolution
1920 x 1080
Display Position Adjustments
Swivel, tilt
Display Type
Diagonal Size
27"
Aspect Ratio
Widescreen
Native Resolution
1920 x 1080
Audio
Speakers - stereo
Mechanical
Swivel, tilt
Environmental Standards
ENERGY STAR Qualified
87ZM C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.58
87ZM C2G 5m Select High Speed HDMI with Ethernet In Stock £19.04
87ZM C2G 10m Select High Speed HDMI with Ethernet In Stock £36.65
87ZM C2G 15m Select High Speed HDMI with Ethernet In Stock £49.65
Diagonal Size: 27in
Response Time: 2ms
Brand: iiyama
Price Range Ex VAT: 150 - 300
