iiyama 21.5" 1920 x 1080 1ms HDMI, VGA, DisplayPort LED Monitor
Quicklinx: D3T7WS00 Mfr#: B2283HS-B3
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£106.26 ex VAT
£127.51 inc VAT
The ProLite B2283HS is an excellent 21.5" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features short response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the installed graphics cards and embedded notebook outputs. The ergonomic stand offers height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments, where workplace flexibility and ergonomics are key factors. The monitor is TCO certified. A perfect solution for education, local government, business and finance markets.
  • HAS and pivot
    With a height adjustable stand you will create an ergonomic work posture and position, that meets all health and safety requirements. This will not only prevent any health issues, but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful, if the application requires more height than width.
  • Flicker-free
    Controlling the monitor's brightness through electric current has allowed to eliminate the screen flicker. You can easily test it yourself - just look at the screen via you smartphone's camera. Your eyes will love it.
  • OverDrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • ACR
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature, that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite B2283HS-B3 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
Display Position Adjustments
Screen Coating
Matte
50.5 cm x 2.3 cm x 37.15 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, TCO Displays, VCCI Class B, CU
Display Type
Energy Class
Class B
32 kWh
21.8 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI , Headphones , DisplayPort , Audio line-in
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
21 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
iiyama 21.5 Bundle deal on iiyama 21.5" 1920 x 1080 1ms HDMI, VGA, DisplayPort LED Monitor
£206.02
D3T7 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
D3T7 StarTech.com Articulating Monitor Arm In Stock £101.86
D3T7 StarTech.com Dual Monitor Stand In Stock £69.36
D3T7 StarTech.com Cubicle Monitor Hanger In Stock £45.29
D3T7 StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
