Don't be fooled by its cool design. The Wireless Body Analysis Scale is a workhorse. Measure, track and share 9 different characteristics of your body composition on our free iHealth mobile app. You can use it online or off. And the scale supports up to 20 users, so go ahead, compare your muscle mass with the whole family.
- iHealth HS5 - bathroom scales
- Product Type
- Bathroom scales - electronic - cordless
- Maximum Weight
- 150 kg
- Maximum Weight (US)
- 330 lbs
- 38 cm x 31 cm x 3.5 cm
- 1.5 kg
- 1 year
- Product Type
- Category
- Personal health
- Special Features
- Wireless synchronisation to mobile
Scales
- Maximum Weight
- 150 kg
- 330 lbs
- Graduation
- 100 g
- Graduation (US)
- 0.2 lbs
- Scale Features
- Calorie display, body fat measure, body water percentage measure, measure units select switch, muscle mass, bone mass, BMI (Body Mass Index), Tap-on technology, 4 sensor technology, visceral fat rating
Settings, Controls & Indicators
- Memory
- 20 user memory
- Directive 1999/5/EC, WEEE, FDA
- Included Accessories
- AA battery x 4
- Battery Form Factor
- AA
- Required Battery Qty
- 4
- Auto Shut Off
- 38 cm
- 31 cm
- 3.5 cm
- 1.5 kg
- Warranty
- 1 year
