Converts a 2.5" SATA HDD or SSD to a 3.5" SATA HDD
Enables the use of a high speed 2.5" SSD in a 3.5" case
With aluminum heat sink for the HDD cooling
Supports SATA 3.0 Gbit/s
Low noise, fan less design
- RaidSonic ICY BOX IB-2535STS - storage drive cage
- Storage drive cage
- Black
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 2.5"
- Compatible Bays
- 1 3.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- Serial ATA-300
- Drive Connector
- 7 pin Serial ATA
- Bay Connector
- 7 pin Serial ATA
- Product Material
- Plastic
- 4.5 cm x 16 cm x 12 cm
- 130 g
- 2.5"
- 3.5" to 2.5"
- Product Material
- Plastic
- Black
- Serial ATA-300
- Bays
- 2.5"
- 1 x SATA 3Gb/s - 7 pin Serial ATA
- Connections
- 1 storage - Serial ATA-300 - 7 pin Serial ATA
- Compatible Bays
- 1 x external 3.5"
- 4.5 cm
- 16 cm
- 12 cm
- 130 g
