The IBM System x3650 M4 blends outstanding uptime, performance and I/O flexibility for cost efficiency and rock-solid reliability. The powerful server offers an energy-smart, affordable, and easy-to-use rack solution with a pay-as-you-grow design to help lower costs and manage risks. With more computing power per Watt and powerful processors, advanced memory support, and greater disk capacity for businesses requiring extreme storage, the x3650 M4 offers balanced performance and density.
Optimized for cost and performance
The IBM System x3650 M4 blends outstanding uptime, performance and I/O flexibility for cost efficiency and rock-solid reliability. The powerful server offers an energy-smart, affordable, and easy-to-use rack solution with a pay-as-you-grow design to help lower costs and manage risks. With more computing power per Watt and powerful processors, advanced memory support, and greater disk capacity for businesses requiring extreme storage, the x3650 M4 offers balanced performance and density. -
Outstanding uptime
With redundant hot-swap fans, disks and power supplies, the x3650 M4 provides a resilient architecture ideal for business-critical applications. Predictive failure analysis and light path diagnostics provide advanced warning on power supplies, fans, VRMs, disks, processors and memory. Redundant hot-swap components make it easy to replace failures without taking your system down.
- Lenovo System x3650 M4 - rack-mountable - Xeon E5-2667V2 3.3 GHz - 8 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, predictive failure analysis (PFA), automatic server restart (ASR)
- Height (Rack Units)
- 2U
- Localisation
- Region: EMEA
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2667V2 / 3.3 GHz (4 GHz) (8-core)
- Processor Socket
- LGA2011 Socket
- Cache Memory
- 25 MB
- Cache Per Processor
- 25 MB
- RAM
- 8 GB DDR3 SDRAM - ECC
- Storage Controller
- SAS (SATA 6Gb/s / SAS 6Gb/s) (ServeRAID M5110e)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200eR2
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Software Included
- IBM ServerGuide, IBM Systems Director, IBM Systems Director Active Energy Manager
- 44.5 cm x 74.6 cm x 8.6 cm
- 25 kg
- Limited warranty - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Led panel
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 2-way
- Front Accessible Bays Qty
- 2
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: EMEA
Processor / Chipset
- CPU
- Intel Xeon E5-2667V2
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011 Socket
- Chipset Type
- Intel C602J
Cache Memory
- Installed Size
- 25 MB
- 25 MB
RAM
- Installed Size
- 8 GB
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 24 (Total) / 23 (empty)
- Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, slots 13 - 24 are available in two-processor configuration only
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 768 GB Load-Reduced , 768 GB HyperCloud , 128 GB unbuffered , 384 GB registered
Hard Drive
- No HDD
Storage Controller
- 1 x SAS - integrated
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Storage Controller Name
- ServeRAID M5110e
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200eR2
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- Intel I350-AM4
- Data Link Protocol
- Remote Management Controller
- Integrated Management Module II (IMM2)
- Wake on LAN (WoL), Teaming support
- IEEE 802.1Q
- Bays
- 1 (total) / 1 (free) x external 5.25" x 1/6H (Slim Line) , 8 (total) / 8 (free) x hot-swap 2.5" , 1 (total) / 1 (free) x external 3.5"
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height
- 6 x USB 2.0 (2 front, 4 rear) , 2 x VGA (1 front, 1 rear) , 1 x serial , 1 x management , 4 x LAN (Gigabit Ethernet) , 2 x USB (2 internal)
- Administrator password, power-on password, predictive failure analysis (PFA), automatic server restart (ASR)
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 900 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Provided
- Software
- 44.5 cm
- 74.6 cm
- 8.6 cm
- 25 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
