The Emulex 10GbE Virtual Fabric Adapters III for IBM System x are members of IBM's comprehensive networking portfolio of 10 Gb Ethernet (10GbE) converged network adapters (CNAs). They deliver industry-leading performance and scalability per watt, reducing requirements for power and cooling. Storage protocol offloads enable the efficient use of computing resources and the support of more virtual machines per CPU, and reduce the number of servers required to support data center demands.
- Emulex Dual Port 10GbE SFP+ Embedded Adapter for IBM System x - network adapter - Advanced Mezzanine Card (AMC) - 2 ports
- Network adapter
- Form Factor
- Integrated
- Interface (Bus) Type
- 1.7 cm x 16 cm x 6 cm
- Ports Qty
- 2 ports
- Data Link Protocol
- 10 GigE
- Data Transfer Rate
- 10 Gbps
- TCP/IP, UDP/IP
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.1Qbb, IEEE 802.1Qaz
- System Requirements
- SUSE Linux Enterprise Server, Microsoft Windows Server, VMware ESX Server, Red Hat Enterprise Linux Server
- Designed For
- System x iDataPlex dx360 M4; System x3550 M4; x3650 M4
- Network adapter - 2 ports
- Form Factor
- Integrated
- Connectivity Technology
- Wired
- 10 Gigabit Ethernet
- 10 Gbps
- TCP/IP, UDP/IP
- Fault tolerance, load balancing, VLAN support, IPv6 support, Jumbo Frames support, TCP Chimney Offload support, IPv4 support, teaming support, PXE support, Large Send Offload (LSO), adaptive load balancing (ALB)
- 2 x network - SFP+
- Compatible Slots
- 1 x Advanced Mezzanine Card (AMC)
- OS Required
- 1.7 cm
- 16 cm
- 6 cm
- 0 °C
- 55 °C
- 5 - 95% (non-condensing)
- Designed For
- Lenovo System x iDataPlex dx360 M4 , Lenovo System x3550 M4 , Lenovo System x3650 M4
