For video editors, streamers, and gamers looking for a USB microphone with great sound quality, the HyperX SoloCast is a must have. Get 24-bit, 96kHz recordings with the SoloCast's high bit depth and sampling rate. It's Plug N Play with a USB-C connection, making it simple to use, with some of our fan-favorite conveniences like the tap-to-mute sensor and LED mute indicator. The versatile microphone has a flexible, adjustable stand and is also compatible with most boom arms, so it can either sit on your desk or work mounted. Certified by TeamSpeak and Discord and compatible with OBS, XSplit, Streamlabs OBS and a number of other programs, it's an extremely streamer-friendly microphone.
                Plug N Play audio recordingGet quality audio recordings with this easy-to-use USB condenser microphone. The cardioid polar pattern prioritizes sound sources directly in front of the microphone.
                Tap-to-Mute sensor with LED status indicatorSimply tap the top of the mic to mute, and the signature LED indicator lets you immediately see whether or not you're broadcasting.
                Flexible, adjustable standThe easy-to-position stand swivels to support a variety of setups. You can even fit it under a monitor if your setup is tight on space.
                Boom arm and mic stand threadingVersatile microphone fits 3/8-inch and 5/8-inch threaded setups, making it compatible with most mic stands or boom arms.
                Multi-device and program compatibilityGet great sound whether you're connecting to a PC, PS5, PS4, or Mac. SoloCast is certified by Discord and TeamSpeak, and works on major streaming platforms like Streamlabs OBS, OBS Studio, and XSplit.
- HyperX SoloCast - microphone
- Product Type
- Microphone - USB
- Recommended Use
- Game console, computer
- Black
- Microphone
- Tabletop
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Cardioid
- Designed For
- HP 250 G9; Laptop 15, 15s, 17; Pavilion Laptop 15; Workstation Z2 G9
- Product Type
- Microphone - USB
- Dimensions & Weight Details
- Microphone stand: 125 g , Microphone with stand: 386 g , Microphone: 261 g
- 429.9 g
- Black
- Recommended Use
Microphone
- Recommended Placing
- Tabletop
- Cardioid
- Connectivity Technology
- Wired
- Sensitivity
- -6 dBV/Pascal
- Frequency Response
- 20 - 20000 Hz
- Mute function
- Audio Input Details
- Cardioid - 20 - 20000 Hz
- Connector Type
- USB
- Included Accessories
- Microphone stand
- Cable Details
- USB-C to USB-A cable - 2 m
- Designed For
- HP 250 G9 Notebook , HP Laptop 15-dw1026nq, 15-dw1094nf, 15-dw3003nq, 15-dw3677nz, 15s-eq1007nm, 15s-eq1008nb, 15s-eq1008no, 15s-eq1085nl, 15s-eq1164nf, 15s-eq1355ng, 15s-eq1530au, 15s-eq1544au, 15s-eq1900nc, 15s-eq2005nw, 15s-eq2019nu, 15s-eq2021au, 15s-eq2032nl, 15s-eq2039nl, 15s-eq2040nl, 15s-eq2045nf, 15s-eq2050nl, 15s-eq2055nu, 15s-eq2059nl, 15s-eq2059ns, 15s-eq2060nl, 15s-eq2061nl, 15s-eq2067nf, 15s-eq2077ns, 15s-eq2088ns, 15s-eq2091ns, 15s-eq2433ng, 15s-eq2458ng, 15s-eq3456ng, 15s-eq3634nz, 15s-fq0084nf, 15s-fq1135ns, 15s-fq2060nl, 15s-fq2060ns, 15s-fq2068ns, 15s-fq2080nl, 15s-fq2081nl, 15s-fq2094nl, 15s-fq2153ng, 15s-fq2153ns, 15s-fq2226nd, 15s-fq2412nd, 15s-fq2596TU, 15s-fq2600tu, 15s-fq3002ny, 15s-fq3005no, 15s-fq3025nf, 15s-fq3412ng, 15s-fq4011tu, 15s-fq4021ns, 15s-fq4023nl, 15s-fq4023ns, 15s-fq4044ns, 15s-fq4045ns, 15s-fq4454ng, 15s-fq4455ng, 15s-fq5304nz, 15s-fq5504nz, 15s-fq5704nz, 17-cn0026nq, 17-cn0040na, 17-cn0334ng, 17-cn0336nf, 17-cn0355ng, 17-cn0413ng, 17-cn0429ng, 17-cn0435nf, 17-cn0448nf, 17-cn0453ng, 17-cn0490nf, 17-cn0515nf, 17-cn0524na, 17-cn0526nf, 17-cn0527nf, 17-cn0780ng, 17-cn0833nd, 17-cn1270nd, 17-cp0002ns, 17-cp0003nl, 17-cp0009na, 17-cp0153ng, 17-cp0255ng, 17-cp0256ng, 17-cp0272ng, 17-cp0293nf, 17-cp0295nf, 17-cp0297nf, 17-cp0437ng, 17-cp0456ng, 17-cp0636ng, 17-cp0658ng, 17-cp0778ng, 17-cp1424nz , HP Pavilion Laptop 15-eg0044nl, 15-eg0050nl, 15-eg0051nl, 15-eg0121nf, 15-eg0122nf, 15-eg0123nf, 15-eg0127od, 15-eg0174ng, 15-eg1003nl, 15-eg1004nl, 15-eg1004ns, 15-eg1007nq, 15-eg1018nu, 15-eg1020nl, 15-eg1027nu, 15-eg1028nu, 15-eg1035nb, 15-eg1035nu, 15-eg1445nd, 15-eg2504nz, 15-eg2530nz, 15-eg2704nz, 15-eg2750nz, 15-eh0523na, 15-eh0900nd, 15-eh1003nq, 15-eh1004nu, 15-eh1005nk, 15-eh1014nl, 15-eh1024nb, 15-eh1031nq, 15-eh1033nb, 15-eh1042nf, 15-eh1042nq, 15-eh1043nf, 15-eh1060au, 15-eh1321nd, 15-eh1360nd, 15-eh1362nd, 15-eh1435nd, 15-eh1436nd, 15-eh2900ng , HP Workstation Z2 G9
