Your basket is empty
HyperX Savage Red 32GB (4x8GB) DDR3 2133MHz CL11 DIMM Memory
Quicklinx: 9QNDWS00 Mfr#: HX321C11SRK4/32
Type: DDR3 SDRAM
Capacity: 32GB
Connection: DIMM 240-pin
Speed: 2133MHz
Data Integrity: Non-ECC
17 in stock
£242.49 ex VAT
£290.98 inc VAT
HyperX HX321C11SRK4/32 is a kit of four 1G x 64-bit (8GB) DDR3-2133 CL11 SDRAM (Synchronous DRAM) 2Rx8, memory module, based on sixteen 512M x 8-bit FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 32GB. Each module has been tested to run at DDR3-2133 at a low latency timing of 11-12-12 at 1.6V. The SPDs are programmed to JEDEC standard latency DDR3-1600 timing of 11-11-11 at 1.5V. Each 240-pin DIMM uses gold contact fingers.
HyperX Savage - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17000)
Latency Timings
CL11 (11-12-12)
Dual rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, quad channel, red heat spreader, low profile heat spreader, asymmetrical heatspreader, unbuffered
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL11 (11-12-12)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Colour Category
Red
HyperX Savage Red 32GB (4x8GB) DDR3 2133MHz CL11 DIMM Memory Bundle deal on HyperX Savage Red 32GB (4x8GB) DDR3 2133MHz CL11 DIMM Memory
£258.81
saving £8.65
Type: DDR3 SDRAM
Capacity: 32GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-17000
Brand: HyperX
Price Range Ex VAT: 150 - 300
