Your basket is empty
HyperX Savage 16GB (8GBx2) DDR4 2666 MHz CL13 DIMM Memory
Quicklinx: BVVQWS00 Mfr#: HX426C13SB2K2/16
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2666MHz
Data Integrity: Non-ECC
£67.08 ex VAT
£80.49 inc VAT
HyperX Savage DDR4 memory offers an unbeatable combination of fast speeds and aggressive timings to complement Intel’s two, four, six or eight core processors for fast video editing, 3D rendering, gaming and AI processing. With speeds of up to 3000 MHz and latencies of CL12–CL15, it’s optimised for Intel’s 100 series chipset and X99 chipset motherboards and features easy overclocking with no need for manual timing adjustments in BIOS.
Available in single modules and kits of two, four and eight and in capacities of up to 128 GB, HyperX Savage DDR4 memory has lower power consumption than DDR3 with 1.2 V or 1.35 V only for all parts. Its asymmetrical, die-cast aluminium heat spreader has a low profile to fit under oversized CPU coolers and provide thermal dissipation to keep your system cooler as it complements the look of the PC hardware and helps you stand out from the square crowd. The black heat spreader and matching PCB are made from quality aluminium material and feature a diamond-cut finish.
HyperX Savage - DDR4 - 16 GB: 2 x 8 GB - DIMM 288-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL13 (13-15-15)
Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL13 (13-15-15)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.35 V - CL13 - 13-14-14 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL13 - 13-15-15
Colour Category
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2666MHz
Registered/Buffered: Unbuffered
CAS Latency: CL13
Standard: PC4-21300
Brand: HyperX
Price Range Ex VAT: 50 - 100
