Your basket is empty
HyperX Predator Blue 16GB (4x4GB) DDR3 1866MHz CL10 DIMM Memory
Quicklinx: 9BQRWS00 Mfr#: KHX18C10T2K4/16
KHX18C10T2K4/16 is a kit of four 512M x 64-bit (4GB) DDR3-1866 CL10 SDRAM (Synchronous DRAM) 1Rx8 memory modules, based on eight 512M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 16GB. Each module kit has been tested to run at DDR3-1866 at a low latency timing of 10-11-10 at 1.5V. The SPDs are programmed to JEDEC standard latency DDR3-1600 timing of 11-11-11 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
HyperX Predator - DDR3 - 16 GB: 4 x 4 GB - DIMM 240-pin
RAM memory
16 GB: 4 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL10 (10-11-10)
Heat sink, single rank, eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, quad channel, unbuffered
Voltage
1.5 V
Lead Plating
Gold
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
2.12
Speed
Latency Timings
CL10 (10-11-10)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
4 x memory - DIMM 240-pin
