Your basket is empty
HyperX Kingston HyperX FURY Pro Gaming Mouse Pad (small)
Quicklinx: B49CWS00 Mfr#: HX-MPFP-SM
21 in stock
£9.28 ex VAT
£11.13 inc VAT
Standard delivery Delivered within 3-5 working days
FURY Pro Gaming Mouse Pad has a high-quality fabric pad that's soft yet resistant and heat-treated for a controlled glide to put you in the lead, whether you're a gamer in a death match or a professional racing the clock. FURY's natural rubber and cross-weave underside provide padding for your wrist to keep you comfortable and supported and help the pad grip the surface firmly for more stability.
  • Superior quality fabric pad
  • Natural rubber for comfort and stability
  • Four different sizes
  • Suitable for any play style and space requirement
  • Portable and durable; easy to roll up and resistant to wear and tear
  • Two-year warranty
Brand: HyperX
Price Range Ex VAT: 0 - 50
