Your basket is empty
HyperX Kingston 8GB 2666MHz DDR3 CL11 DIMM (Kit of 2) XMP HyperX Predator
Quicklinx: C593WS00 Mfr#: HX326C11PB3K2/8
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 2666MHz
Data Integrity: Non-ECC
Hurry, only 1 left in stock!
£116.69 ex VAT
£140.02 inc VAT
HyperX® Predator memory has the fastest speeds, lowest latencies and highest capacities available in HyperX memory. It’s designed for and compatible with all popular brands of motherboards. HyperX Predator is ultra-reliable and 100 per cent factory tested to ensure that it will deliver higher performance, ultraresponsive multitasking and a faster system.Predator features a tall heat spreader for greater heat dissipation, and its black PCB complements the look and design of the latest PC hardware. Intel XMP-certified kits are available up to 2800MHz. Users can overclock their platforms simply by selecting a profile, with no need for manual adjustments in BIOS.For added peace of mind, HyperX Predator is backed by a lifetime warranty, free technical support and legendary reliability.
Kingston HyperX Predator - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC3-21300)
Latency Timings
CL11 (11-14-15)
Heat sink, single rank, eight banks, Serial Presence Detect (SPD), Intel Extreme Memory Profiles (XMP), unbuffered
Voltage
1.65 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.614
Speed
Latency Timings
CL11 (11-14-15)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.65 V
Lead Plating
Gold
RAM Performance
SPD - 1600 MHz - 1.5 V - CL11 - 11-11-11 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.65 V - CL11 - 11-14-14 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.65 V - CL11 - 11-14-15
Colour Category
HyperX Kingston 8GB 2666MHz DDR3 CL11 DIMM (Kit of 2) XMP HyperX Predator Bundle deal on HyperX Kingston 8GB 2666MHz DDR3 CL11 DIMM (Kit of 2) XMP HyperX Predator
£133.01
saving £8.65
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 2666MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-21300
Brand: HyperX
Price Range Ex VAT: 100 - 150
