HyperX Predator SSD offers large capacities and incredible speeds with both compressible and incompressible data to take your system to the edge. Faster than SATA-based SSDs, it delivers speeds of up to 1400 MB/s read and 1000 MB/s write for ultra-responsive multitasking and an overall faster system.
It features a PCIe Gen 2.0 x4 interface for high performance and an M.2 form factor to fit the next generation of desktops with an M.2 PCIe slot.
- HyperX Predator - SSD - 240 GB - PCIe 2.0 x4
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- M.2 2280
- Interface
- PCIe 2.0 x4
- Marvell 88SS9293 controller
- 22 mm x 80 mm x 3.5 mm
- 10 g
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- M.2 2280
- Interface
- PCIe 2.0 x4
- 22 mm
- 80 mm
- 3.5 mm
- 10 g
Performance
- Drive Writes Per Day (DWPD)
- 1.6
- SSD Endurance
- 415 TB
- Internal Data Rate
- 1400 MBps (read) / 600 MBps (write)
- 4KB Random Read
- 120000 IOPS
- 4KB Random Write
- 78000 IOPS
- Maximum 4KB Random Write
- 119000 IOPS
- Maximum 4KB Random Read
- 160000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x PCI Express 2.0 x4 - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 1.38 Watt (idle) , 1.99 Watt (read) , 8.25 Watt (write) , 1.4 Watt (average)
- ISO 9001:2008, SGS
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
