HyperX Savage solid-state drive offers extreme performance for the extreme performer. The fastest HyperX SATA-based SSD, it's powered by a quad-core, 8-channel Phison S10 controller that delivers incredible speeds of up to 560 MB/s read and 530 MB/s write, with read/write IOPS up to 100k/89k.
The result is ultra-responsive multitasking and an overall faster system that maintains performance even as the drive fills up. With its low profile and slim, 7mm form factor, HyperX Savage SSD fits in most notebooks, desktops and HTPC builds.
- HyperX Savage - SSD - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- Form Factor
- 2.5" (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Phison PS3110-S10 controller
- 69.9 mm x 100 mm x 7 mm
- 96 g
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.9 mm
- 100 mm
- 7 mm
- 96 g
Performance
- Drive Writes Per Day (DWPD)
- 0.89
- SSD Endurance
- 113 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 360 MBps (write)
- 4KB Random Read
- 93000 IOPS
- 4KB Random Write
- 83000 IOPS
- Maximum 4KB Random Write
- 84000 IOPS
- Maximum 4KB Random Read
- 100000 IOPS
Reliability
- MTBF
- 1,000,000 hour(s)
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" or 3.5" (with included bay adapter)
- Power Consumption
- 1.4 Watt (read) , 4.35 Watt (write) , 0.39 Watt (idle) , 0.5 Watt (average)
- Included Accessories
- 3.5-inch bay adapter, 7mm to 9.5mm holder
- Mounting Kit
- Included
- ISO 9001:2008, SGS
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
