Powerful SO-DIMM performance optimized for Intel's 100 series chipset.
Make an Impact in your game with powerful HyperX Impact DDR4 SO-DIMM. It automatically overclocks to the highest frequency published, up to 2666 MHz, without the need to adjust system BIOS settings, to support platforms that use Intel's CPU technologies. You get instant top-level performance with lower voltage that helps your system run cooler, quieter and more efficiently. All you'll ever miss is lag time.
HyperX Impact DDR4 has a slim form for easy installation in slim or ultra-slim notebooks and features a sleek design with a matching PCB that adds an aggressive look.
- HyperX Impact - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL13 (13-13-13)
- Dual rank, On-Die Termination (ODT), Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL13 (13-13-13)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.2 V
