HyperX Impact Black 16GB (2x8GB) DDR3L 1600MHz CL9 SODIMM Memory
Quicklinx: 9JDXWS00 Mfr#: HX316LS9IBK2/16
Type: DDR3L SDRAM
Capacity: 16GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
More than 50 in stock
£60.16 ex VAT
£72.19 inc VAT
High-performance memory for gaming notebooks, small form factor PCs and Steam Box systems
HyperX® Impact memory boasts the world's fastest SO-DIMM frequency - 2666MHz - to keep you ahead of the curve and level up your game. It automatically recognises the platform it's plugged into and auto overclocks to the highest frequency published (up to 2400MHz1) with no need to adjust system BIOS settings. So you get extreme performance that supports notebooks using either AMD or the latest Intel CPU technologies with no hassle at all - even if you're a newbie.
Impact makes your game hotter while keeping your system cool. It has low voltage settings at 1.35V for less power consumption, reduced heat generation and quiet computing. Its slim, sleek new look lets you stand out in the crowd while the thin thermal label allows for installation in slim or ultra-slim notebooks.
Best of all, HyperX Impact delivers high performance at a low cost. It's gamer approved and backed by a lifetime warranty, free technical support and legendary reliability.
  • Auto overclock up to 2400MHz2
  • Low voltage setting at 1.35V
  • Slim and sleek new look compatible with ultra-thin notebooks
  • SO-DIMM form factor -- features stylish and slim thermal label for an easy flfit
  • Easy to install -- automatic overclocking; plug-and-play functionality means no adjustments in BIOS needed
  • Eco-friendly -- low voltage settings for cooler and quieter computing
  • Reliable -- 100 per cent factory tested
  • Guaranteed --fllifetime warranty, free technical support
  • Capacities 4GB, 8GB (single) and 8GB, 16GB (kits)
  • Frequency (speed) 1600MHz-2400MHz
  • Dual Channel
  • Latency CL9-CL12
  • Voltage 1.35V
  • Operating temperature 0°C to 85°C
  • Storage temperature -55°C to 100°C
  • Dimensions SO-DIMM: 30mm x 67.6mm
  • Chipsets Compatible with HM65, HM67, HM70, HM75, HM76, HM77, HM86, HM87, QM67, QM87, QS67, UM67 and UM77 Intel chipsets
HyperX Impact Black Series - DDR3L - 16 GB: 2 x 8 GB - SO-DIMM 204-pin - unbuffered
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL9 (9-9-9)
Single rank, eight banks, On-Die Termination (ODT), dual channel, Low Voltage, unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9 (9-9-9)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Colour Category
Type: DDR3L SDRAM
Capacity: 16GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3L-12800
Brand: HyperX
Price Range Ex VAT: 50 - 100
