Your basket is empty
HyperX Impact 8GB DDR4 2133MHz CL13 SODIMM Memory
Quicklinx: BMK1WS00 Mfr#: HX421S13IB/8
Type: DDR4 SDRAM
Capacity: 8GB
Connection: SO-DIMM 260-pin
Speed: 2133MHz
Data Integrity: Non-ECC
33 in stock
£48.19 ex VAT
£57.82 inc VAT
Standard delivery Delivered within 3-5 working days
Powerful SO-DIMM performance optimized for Intel's 100 series chipset.
Make an Impact in your game with powerful HyperX Impact DDR4 SO-DIMM. It automatically overclocks to the highest frequency published, up to 2666 MHz, without the need to adjust system BIOS settings, to support platforms that use Intel's CPU technologies. You get instant top-level performance with lower voltage that helps your system run cooler, quieter and more efficiently. All you'll ever miss is lag time.
HyperX Impact DDR4 has a slim form for easy installation in slim or ultra-slim notebooks and features a sleek design with a matching PCB that adds an aggressive look.
Kingston HyperX Impact - DDR4 - 8 GB - SO-DIMM 260-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL13 (13-13-13)
Dual rank, On-Die Termination (ODT), Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL13 (13-13-13)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.2 V
HyperX Impact 8GB DDR4 2133MHz CL13 SODIMM Memory Bundle deal on HyperX Impact 8GB DDR4 2133MHz CL13 SODIMM Memory
£64.51
saving £8.65
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL13
Standard: PC4-17000
Brand: HyperX
Price Range Ex VAT: 0 - 50
