High-performance memory for gaming notebooks, small form factor PCs and Steam Box systems
HyperX® Impact memory boasts the world's fastest SO-DIMM frequency - 2666MHz - to keep you ahead of the curve and level up your game. It automatically recognises the platform it's plugged into and auto overclocks to the highest frequency published (up to 2400MHz1) with no need to adjust system BIOS settings. So you get extreme performance that supports notebooks using either AMD or the latest Intel CPU technologies with no hassle at all - even if you're a newbie.
Impact makes your game hotter while keeping your system cool. It has low voltage settings at 1.35V for less power consumption, reduced heat generation and quiet computing. Its slim, sleek new look lets you stand out in the crowd while the thin thermal label allows for installation in slim or ultra-slim notebooks.
Best of all, HyperX Impact delivers high performance at a low cost. It's gamer approved and backed by a lifetime warranty, free technical support and legendary reliability.
- Auto overclock up to 2400MHz
- Low voltage setting at 1.35V
- Slim and sleek new look compatible with ultra-thin notebooks
- SO-DIMM form factor - features stylish and slim thermal label for an easy flfit
- Easy to install - automatic overclocking; plug-and-play functionality means no adjustments in BIOS needed
- Eco-friendly - low voltage settings for cooler and quieter computing
- Reliable - 100 per cent factory tested
- Guaranteed -fllifetime warranty, free technical support
- Capacities 4GB, 8GB (single) and 8GB, 16GB (kits)
- Frequency (speed) 1600MHz-2400MHz
- Dual Channel
- Latency CL9-CL12
- Voltage 1.35V
- Operating temperature 0C to 85C
- Storage temperature -55C to 100C
- Dimensions SO-DIMM: 30mm x 67.6mm
- Chipsets Compatible with HM65, HM67, HM70, HM75, HM76, HM77, HM86, HM87, QM67, QM87, QS67, UM67 and UM77 Intel chipsets
- HyperX Impact Black Series - DDR3L - module - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3L SDRAM - SO-DIMM 204-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3L-12800)
- Latency Timings
- CL9 (9-9-9)
- Single rank, eight banks, On-Die Termination (ODT), Low Voltage, unbuffered
- Voltage
- 1.35 / 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL9 (9-9-9)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.35 / 1.5 V
- Lead Plating
- Gold
- Colour Category
- Black
