HyperX® FURY DDR4 automatically recognises the platform it’s plugged into and automatically overclocks to the highest frequency published, up to 2666MHz, for hassle-free, plug-and-play functionality. It delivers automatic top-level performance for motherboards featuring Intel’s 200 series and X99 chipsets and complements Intel’s 2, 4, 6, 8 and 10-core processors for faster video editing, 3D rendering, gaming and AI processing. Available in speeds from 2133MHz–2666MHz, CL14–16 latencies and capacities of 4GB, 8GB and 16GB single modules and 8GB–64GB kits, HyperX FURY DDR4 is a minimal investment in premium components that results in faster speeds, higher performance and enhanced reliability – plus it looks really cool. It stays cool, too, thanks to 1.2V power consumption resulting in less heat, with a lower voltage specification than DDR3. Its stylish, low-profile design complements the look of the latest PC hardware while helping you stand out from the crowd of squared designs.
- HyperX FURY - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
- Product Type
- Memory kit
- Capacity
- 32 GB: 2 x 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL15 (15-15-15)
- Dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), dual channel, Black PCB, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 32 GB: 2 x 16 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Module Height (inch)
- 1.34
- Speed
- Latency Timings
- CL15 (15-15-15)
- Non-ECC
- Module Configuration
- 2048 x 64
- Chips Organization
- 1024 x 8
- Voltage
- 1.2 V
- Lead Plating
- Gold
- RAM Performance
- SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , SPD - 2400 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
- Colour Category
- White
