HyperX FURY White 32GB (2x16GB) DDR4 2400MHz CL15 DIMM Memory
Quicklinx: CSQJWS00 Mfr#: HX424C15FWK2/32
HyperX® FURY DDR4 automatically recognises the platform it’s plugged into and automatically overclocks to the highest frequency published, up to 2666MHz, for hassle-free, plug-and-play functionality. It delivers automatic top-level performance for motherboards featuring Intel’s 200 series and X99 chipsets and complements Intel’s 2, 4, 6, 8 and 10-core processors for faster video editing, 3D rendering, gaming and AI processing. Available in speeds from 2133MHz–2666MHz, CL14–16 latencies and capacities of 4GB, 8GB and 16GB single modules and 8GB–64GB kits, HyperX FURY DDR4 is a minimal investment in premium components that results in faster speeds, higher performance and enhanced reliability – plus it looks really cool. It stays cool, too, thanks to 1.2V power consumption resulting in less heat, with a lower voltage specification than DDR3. Its stylish, low-profile design complements the look of the latest PC hardware while helping you stand out from the crowd of squared designs.
HyperX FURY - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory kit
32 GB: 2 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL15 (15-15-15)
Dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), dual channel, Black PCB, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 2 x 16 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL15 (15-15-15)
Non-ECC
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , SPD - 2400 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
Colour Category
White
