HyperX FURY Black 8GB (2x4GB) DDR3L 1600MHz CL10 DIMM Memory
Quicklinx: BMJSWS00 Mfr#: HX316LC10FBK2/8
Type: DDR3L SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£33.21 ex VAT
£39.85 inc VAT
Auto-overclocking up to 1866 MHz to get you in the game faster.
HyperX FURY DDR3 memory automatically overclocks up to 1866 MHz for hassle-free, Plug and Play functionality that gets you in the game faster and instant top-level performance that helps you win it. With voltages as low as 1,35V, it draws less power and generates less heat, while supporting Intel's 100 Series chipset.
Its asymmetric, aggressive design lets you stand out from the crowd of "squared" designs and features quality aluminum and a diamond-cut finish.
HyperX FURY - DDR3L - 8 GB: 2 x 4 GB - DIMM 240-pin - unbuffered
RAM memory
8 GB: 2 4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL10 (10-10-10-30)
Single rank, black heatsink, eight banks, On-Die Termination (ODT), dual channel, Low Voltage, Black PCB, FURY asymmetric heatspreader, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.35 / 1.5 V
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL10 (10-10-10-30)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
RAM Performance
SPD - 1066 MHz - 1.35 / 1.5 V - CL7 - 7-7-7 , SPD - 1333 MHz - 1.35 / 1.5 V - CL9 - 9-9-9 , SPD - 1600 MHz - 1.35 / 1.5 V - CL10 - 10-10-10 , Intel Extreme Memory Profiles (XMP 2.0) - 1600 MHz - 1.35 / 1.5 V - CL10 - 10-10-10
Colour Category
Type: DDR3L SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL10
Standard: PC3L-12800
Brand: HyperX
Price Range Ex VAT: 0 - 50
