HyperX FURY Black 16GB (8GBx2) DDR3 1866MHz CL10 DIMM Memory
Quicklinx: 9DCJWS00 Mfr#: HX318C10FBK2/16
Type: DDR3 SDRAM
Capacity: 16GB
Connection: DIMM 240-pin
Speed: 1866MHz
Data Integrity: Non-ECC
£66.26 ex VAT
£79.51 inc VAT
Get in the game with HyperX FURY. Even newbies get up to speed fast, since FURY automatically recognises its host platform and automatically overclocks to the highest frequency published - up to 1866MHz - providing plenty of power for your next deathmatch. Affordably priced, FURY's asymmetric heat spreader design is available in black, blue, red and- for the first time in the HyperX line -white, with a black PCB. It's 100 per cent tested and backed by a lifetime warranty and free technical support.
  • Asymmetric heat spreader for stylish heat dissipation
  • Compatible with Intel and AMD platforms
Features & Benefits
  • Unique -- tested with all popular brands of motherboards
  • Easy to install -- Plug-and-Play functionality
  • Automatic overclocking -- reach faster speeds and higher capacities just by installing the memory, no adjustments in BIOS needed
  • Reliable -- 100 per cent factory tested
  • Lifetime warranty, free technical support
  • Capacity 16GB
  • Frequency speed 1866MHz
  • CAS latency 10-10-10-30
  • Voltage 1.5V
  • Operating temperature 0C to 85C
  • Storage temperature -55C to 100C
  • Dimensions 133.35mm x 32.8mm
  • Compatible with P55, H67, P67, Z68, Z77, Z87 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
    Get in the game faster with automatic high overclocking.
  • Aggressive look, asymmetrical design
    Its innovative design makes HyperX FURY DDR3 memory stand out from the crowd. Its asymmetrical heat spreader and PCB complement the look of many systems.
HyperX FURY - DDR3 - 16 GB: 2 x 8 GB - DIMM 240-pin - unbuffered
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL10 (10-10-10-30)
Black PCB, FURY asymmetric heatspreader, unbuffered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL10 (10-10-10-30)
Non-ECC
Module Configuration
1024 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Colour Category
Type: DDR3 SDRAM
Capacity: 16GB
Speed: 1866MHz
Registered/Buffered: Unbuffered
CAS Latency: CL10
Standard: PC3-14900
Brand: HyperX
Price Range Ex VAT: 50 - 100
