Plug and Play for high performance with Intel's 100 Series and X99 chipsets.
HyperX FURY DDR4 memory automatically overclocks to the highest frequency published, up to 2666 MHz, to deliver instant top-level performance for motherboards with Intel's 100 Series and X99 chipsets.
It's a small investment for premium components that complement Intel's 2, 4, 6 and 8-core processors for faster video editing, 3D rendering, gaming and AI processing.
Its stylish low-profile heat spreader with signature FURY design lets you show off your rig in style.
- HyperX FURY - DDR4 - kit - 16 GB: 2 x 8 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2666 MHz (PC4-21300)
- Latency Timings
- CL15 (15-17-17)
- Dual rank, black heatsink, On-Die Termination (ODT), dual channel, Black PCB, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Module Height (inch)
- 1.34
- Speed
- Latency Timings
- CL15 (15-17-17)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.2 V
- RAM Performance
- SPD - 2133 MHz - 1.2 V - CL12 - 12-14-14 , SPD - 2400 MHz - 1.2 V - CL14 - 14-16-16 , SPD - 2666 MHz - 1.2 V - CL15 - 15-17-17 , Intel Extreme Memory Profiles (XMP 2.0) - 2666 MHz - 1.2 V - CL15 - 15-17-17
- Colour Category
- Black
