HyperX FURY Black 8GB DDR4 2400MHz CL15 DIMM Memory
Quicklinx: C11GWS00 Mfr#: HX424C15FB2/8
Engineered and tested to deliver extreme performance, Kingston HyperX easily endures the most rigorous demands of any creative professional, gamer or PC enthusiast.
  • Plug and play
    Get the speed you want, hassle free. HyperX FURY DDR4 is the first product line to offer automatic overclocking up to the highest frequency published.
  • Low power consumption
    DDR4's lower power requirements mean less heat and higher reliability. Low 1.2 volts draw less power from your system, which results in a cooler and quieter PC.
  • Low profile stylish heat spreader
    Stand out from the crowd and show your style with FURY's asymmetrical signature heat spreader.
HyperX FURY - DDR4 - module - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL15 (15-15-15)
Single rank, black heatsink, On-Die Termination (ODT), Serial Presence Detect (SPD), Black PCB, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL15 (15-15-15)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , SPD - 2400 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
Colour Category
