Your basket is empty
HyperX FURY 8GB DDR4 2400MHz CL15 DIMM Memory
Quicklinx: BKLKWS00 Mfr#: HX424C15FB/8
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: Non-ECC
Hurry, only 1 left in stock!
£44.62 ex VAT
£53.54 inc VAT
Express delivery Order within the next 46 minutes for delivery tomorrow
Plug and Play for high performance with Intel's 100 Series and X99 chipsets.
HyperX FURY DDR4 memory automatically overclocks to the highest frequency published, up to 2666 MHz, to deliver instant top-level performance for motherboards with Intel's 100 Series and X99 chipsets.
It's a small investment for premium components that complement Intel's 2, 4, 6 and 8-core processors for faster video editing, 3D rendering, gaming and AI processing.
Its stylish low-profile heat spreader with signature FURY design lets you show off your rig in style.
Kingston HyperX FURY - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL15 (15-15-15)
Dual rank, black heatsink, On-Die Termination (ODT), Black PCB, low profile heat spreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL15 (15-15-15)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.2 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , SPD - 2400 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
Colour Category
HyperX FURY 8GB DDR4 2400MHz CL15 DIMM Memory Bundle deal on HyperX FURY 8GB DDR4 2400MHz CL15 DIMM Memory
£60.94
saving £8.65
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-19200
Brand: HyperX
Price Range Ex VAT: 0 - 50
