Your basket is empty
HyperX FURY 8GB (4GBx2) DDR4 2133MHz CL14 DIMM Memory
Quicklinx: B49KWS00 Mfr#: HX421C14FBK2/8
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 2133MHz
Data Integrity: Non-ECC
£42.87 ex VAT
£51.44 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
Plug and Play for high performance with Intel's 100 Series and X99 chipsets.
HyperX FURY DDR4 memory automatically overclocks to the highest frequency published, up to 2666 MHz, to deliver instant top-level performance for motherboards with Intel's 100 Series and X99 chipsets.
It's a small investment for premium components that complement Intel's 2, 4, 6 and 8-core processors for faster video editing, 3D rendering, gaming and AI processing.
Its stylish low-profile heat spreader with signature FURY design lets you show off your rig in style.
Kingston HyperX FURY - DDR4 - 8 GB : 2 x 4 GB - DIMM 288-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC4-17000 )
Latency Timings
CL14 ( 14-14-14 )
Single rank, black heatsink, On-Die Termination (ODT), Black PCB, low profile heat spreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL14 ( 14-14-14 )
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
Colour Category
HyperX FURY 8GB (4GBx2) DDR4 2133MHz CL14 DIMM Memory Bundle deal on HyperX FURY 8GB (4GBx2) DDR4 2133MHz CL14 DIMM Memory
£59.23
saving £7.75
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL14
Standard: PC4-17000
Brand: HyperX
Price Range Ex VAT: 0 - 50
