HyperX CloudX™ Pro Gaming Headset is designed for Xbox and tested and approved by Microsoft. It works with the Xbox Elite Wireless controller and other Xbox One controllers with a 3.5mm stereo headset jack and provides connectivity from the headset to console and mobile devices1. With additional Windows compatibility, it comes with a 2M PC extension cable with stereo and mic plugs. HyperX CloudX features immersive in-game audio so you can lose yourself in the game while you’re winning.
- Official Xbox licensed headset.
- Award-winning total comfort.
- Immersive in-game audio.
- Solid, durable aluminum frame.
- In-line audio control.
- Detachable noise-cancellation microphone.
- Hard-shell carrying case.
- HyperX CloudX - headset
- Product Type
- Headset - wired
- Compatibility
- Windows
- Recommended Use
- Game console, computer
- Localisation
- EMEA
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
- Impedance
- 60 Ohm
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Controls
- Volume, microphone on/off
- 2-year warranty
- Product Type
- Headset - wired
- Compatibility
- Windows
- 322 g
- Body Material
- Aluminium
- Headband Material
- Leatherette
- Earpad Material
- Memory foam
- Recommended Use
- Localisation
- EMEA
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 15 - 25000 Hz
- Total Harmonic Distortion (THD)
- <2%
- Sensitivity
- 98 dB
- Impedance
- 60 Ohm
- Diaphragm
- 53 mm
- Magnet Material
- Neodymium
- In-Cord Volume Control
Microphone
- Boom
- Sensitivity
- -39 dB
- 50 - 18000 Hz
- Audio Input Details
- Uni-directional - 50 - 18000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole) , Microphone (mini-phone stereo 3.5 mm)
Cable
- Cable Length
- 1.3 m
- Included Accessories
- Carrying case, velour ear pads, detachable microphone
- Cable Details
- Headset cable - 1.3 m , Headset extension cable - 2 m
- Limited warranty - 2 years
