HyperX Cloud Stinger Headset
Quicklinx: CD31WS00 Mfr#: HX-HSCS-BK/EM
Recommended Use: Computer, Game console, Portable electronics
Connectivity: Wired
Earcover : Binaural
£45.00 ex VAT
£54.00 inc VAT
HyperX Cloud Stinger™ is the ideal headset for gamers looking for lightweight comfort, superior sound quality and added convenience. At just 275 grams, it’s comfortable on your neck and its ear cups rotate in a 90-degree angle for a better fit. Its 50mm directional drivers position sound directly into the ear for audio precision and gaming-grade sound quality. For ultimate comfort in prolonged gaming sessions, it features high-quality HyperX signature memory foam.
• Lightweight headset with 90-degree rotating ear cups
•50mm directional drivers for audio precision
• HyperX signature memory foam
• Adjustable steel slider
• Intuitive volume control on headset ear cup
• Swivel-to-mute noise-cancellation microphone • Multi-platform compatibility"
  • 90-degree rotating ear cups
    HyperX Cloud Stinger's ear cups rotate in a 90-degree angle to fit better around your neck, so you can play in comfort for hours.
  • Lightweight comfort
    HyperX Cloud Stinger won't weigh you down, making it ideal for prolonged gaming sessions.
  • 50mm directional drivers for audio precision
    The 50mm drivers are parallel to the ear, to position sound directly into the ear for gaming-grade sound quality.
    HyperX Cloud Stinger's high-quality, adjustable solid steel slider is built for long-lasting durability and stability.
    Conveniently mute the microphone by flipping it vertically against the head. HyperX Cloud Stinger's built-in passive noise cancellation reduces background noise for clearer voice quality.
HyperX Cloud Stinger - headset
Headset - wired
Compatibility
iPhone, iPad, Android phone, Windows phone, Mac, Windows
Recommended Use
Game console, portable electronics, computer
EMEA
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Microphone
Boom
Controls
Volume, microphone on/off
Xbox One, Xbox One S; Nintendo Wii U; Sony PlayStation 4, Sony PlayStation 4 Pro, Sony PlayStation 4 Slim
Headset - wired
Compatibility
311 g
Earpad Material
Leatherette, memory foam
Recommended Use
EMEA
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Diaphragm
50 mm
In-Cord Volume Control
Adjustable Headband
Microphone
Boom
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1.3 m
Cable Details
Headset cable - 1.3 m , Audio splitter - 1.7 m
Xbox One, Xbox One S , Nintendo Wii U , Sony PlayStation 4, Sony PlayStation 4 Pro, Sony PlayStation 4 Slim
Recommended Use: Game console
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
Brand: HyperX
