HyperX Cloud RevolverS headset
Quicklinx: CS0QWS00 Mfr#: HX-HSCRS-GM/EM
Recommended Use: Computer, Game console, Portable electronics
Connectivity: Wired
Earcover : Binaural
£140.17 ex VAT
£168.20 inc VAT
HyperX Cloud Revolver S is primed for action with Plug N Play surround 7.1 audio. Hear every footstep, explosion and gunshot with cinematic clarity as the simulated seven positional speakers provide precise sound with distance and depth. The advanced USB digital signal processing sound card handles everything, delivering consistent premium-quality sound, no matter what system you're playing on. Backlit buttons on the clippable audio control box allow you to quickly activate audio, mute and regulate mic and output levels. Bass boost and vocal equalizer modes let you swap between setups tuned for games, streaming, music or movies. Revolver S has a studio-grade sound stage that excels in FPS and open environment settings, letting you hear sounds further away more accurately.
The unique Revolver S driver design separates the lows, mids and highs and the re-engineered profiles produce sounds audiophiles will rave about. Serious gamers and streamers will love the higher-quality dense HyperX signature memory foam and the wider headband that reduces head pressure and more evenly distributes weight. Cloud Revolver S has a solid-steel frame for long-lasting durability and stability and is built to deliver sonic perfection for years. Closed ear cups block out outside noise to fully immerse you in Cloud's signature crisp, clear sound quality and enhanced bass.
  • Plug N Play surround 7.1 audio technology
    HyperX Cloud Revolver S is ready for battle with Plug N Play surround 7.1 audio. Make every part of your audio experience shine with cinematic clarity.
  • Advanced USB audio control box with DSP sound card
    The Digital Signal Processing sound card boosts your audio and enhances noise cancellation for an optimized gaming experience. Backlit buttons allow you to mute and adjust mic and output levels instantly with the clippable audio control box.
  • Studio-grade sound stage lets you hear enemies before they hear you
    Revolver S features a studio-grade sound stage that excels in FPS and open environment settings, allowing you to accurately hear sounds from further away, giving you an edge on the enemy.
  • Next-generation directional drivers pump out crisp, precise audio
    Directional drivers positioned parallel to the ears crank out crisp, precise audio with enhanced bass.
HyperX Cloud Revolver S - headset
Headset - wired - USB, 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Game console, portable electronics, computer
EMEA
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 12 - 28000 Hz - Sensitivity 100.5 dB/mW
Impedance
30 Ohm
Max Input Power
500 mW
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Operation Mode
Uni-directional
Controls
Mute, volume
Compatibility
Mac, Windows
376 g
Body Material
Steel
Earpad Material
Memory foam
Recommended Use
EMEA
Audio Output
Full size
Headphones Cup Type
Closed
Dynamic
Wired
Sound Output Mode
Stereo
Sound Effects
Frequency Response
12 - 28000 Hz
Max Input Power
500 mW
Total Harmonic Distortion (THD)
<2%
Sensitivity
100.5 dB/mW
Impedance
30 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
Microphone
Boom
Electret condenser
Uni-directional
Sensitivity
-40 dB
Frequency Response
50 - 18000 Hz
Audio Input Details
Uni-directional - 50 - 18000 Hz
Remote Control
Controls
Mute, volume
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1 m
External USB control box, detachable microphone
Cable Details
Audio extension cable
Recommended Use: Game console
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
Brand: HyperX
Price Range Ex VAT: 100 - 150
