HyperX Cloud Pro Gaming Headset Silver - PS4, Xbox One, PC
Quicklinx: D0R2WS00 Mfr#: HX-HSCL-SR/NA
HyperX Cloud is designed to meet the demands of serious console gamers. Cloud in silver has convenient in-line audio control that saves you from navigating through system menus and puts control at your fingertips. The durable aluminum frame is designed for long-lasting reliability and to withstand the damage of daily gaming. The 100% memory foam ear cushions and leatherette-padded headband provide amazing comfort for those long weekends and late nights of gaming. HiFi capable 53mm drivers and enhanced bass reproduction pump out crystal clear high, mids and lows, and the closed cup design silences the outside world to completely immerse you in your game. Cloud's microphone can be adjusted the way you like it, and it eliminates background noise so you come across loud and clear. When you're ready to listen to music, simply unplug the microphone and stow it for later.
  • In-line audio control
    Cloud in silver features in-line audio control designed with console gamers in mind; players will no longer have to navigate system menus to adjust volume and mute the microphone.
  • Durable aluminum frame
    Cloud is constructed with a durable aluminum frame that provides long-lasting durability.
  • Award-winning comfort
    100% memory foam cushions and leatherette-padded headband provide award-winning comfort so you can enjoy marathon gaming sessions without pain.
  • Immersive in-game audio
    HyperX Cloud's HiFi capable 533mm drivers and enhanced bass reproduction pump out crisp high-end, vibrant midrange and rich lows. The closed cup design blocks out outside noise to provide total gaming immersion.
  • Detachable noise-cancellation microphone
    The adjustable, noise-canceling microphone eliminates background noise so you'll be confident that you're communicating loud and clear. When it's time to listen to music, simply unplug the detachable microphone.
  • TeamSpeak and Discord Certified
    HyperX Cloud has been certified by TeamSpeak and Discord and is compatible with Skype, Ventrilo, Mumble, RaidCall and many other programs. During testing, no audible echoes, background noise or voice distortions were detected, so your team will have crystal-clear communication with Cloud.
  • Distinctive style with ample accessories
    Cloud in silver provides you yet another HyperX style to choose from and comes with a highquality mesh travel pouch to hold the headset, detachable mic and the 2M PC extension cable.
HyperX Cloud Silver - headset
Headset - wired - 3.5 mm jack
Recommended Use
Game console, portable electronics, computer
North America
Silver
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
Impedance
60 Ohm
Max Input Power
300 mW
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Operation Mode
Uni-directional
Controls
Volume, microphone on/mute
322 g
Silver
Body Material
Aluminium
Headband Material
Leatherette
Earpad Material
Memory foam
Recommended Use
North America
Audio Output
Full size
Headphones Cup Type
Closed
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
15 - 25000 Hz
Max Input Power
300 mW
Total Harmonic Distortion (THD)
<2%
Sensitivity
98 dB
Impedance
60 Ohm
Diaphragm
53 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Boom
Detachable headset microphone
Electret condenser
Uni-directional
Sensitivity
-39 dB
Frequency Response
50 - 18000 Hz
Audio Input Details
Uni-directional - 50 - 18000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1.3 m
Detachable microphone
Cable Details
Headset cable - 1.3 m , Headset extension cable - 2 m
