HyperX Cloud II Limited Edition Full Size Headset - Pink
Quicklinx: BJVTWS00 Mfr#: KHX-HSCP-PK
HyperX Cloud II Headset
HyperX™ Cloud II features a newly designed USB sound card audio control box that amplifies audio and voice for an optimal Hi-Fi gaming experience, so you can hear what you've been missing. Open up a world of detail other gamers will never know - the rustle of a camper's boot, the scuttle in a distant vent. Its independent audio and microphone volume control lets you adjust not only sound volume but also mic volume and easily toggle Surround Sound 7.1 or the mic sound on and off. This next-generation headset generates virtual 7.1 surround sound with distance and depth to enhance your gaming, movie or music experience. Pinpoint your opponents' location in the game and strike before he sees you coming.
  • Advanced USB audio control box with built-in DSP sound card
  • Hi-Fi capable with 53mm drivers for supreme audio quality
  • Hardware-driven virtual 7.1 surround sound
  • Comfortable, 100% memory foam on headband and leatherette cushions
  • Pro-Gaming optimized with closed cup design for passive noise cancellation
  • Compatible - USB connectivity for PC & Mac. Stereo compatible with PS4, Xbox One1
HyperX Cloud II - headset
Headset - wired
Recommended Use
Game console, portable electronics, computer
Pink
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
Impedance
60 Ohm
Microphone
Detachable - boom
Microphone Technology
Electret condenser
Controls
Volume, microphone on/off, surround on/off
Headset - wired
320 g
Pink
Body Material
Memory foam
Headband Material
Foam
Earpad Material
Leatherette
Recommended Use
Audio Output
Full size
Headphones Cup Type
Closed
Dynamic
Wired
Sound Output Mode
Stereo
Sound Effects
Frequency Response
15 - 25000 Hz
Total Harmonic Distortion (THD)
<2%
Sensitivity
98 dB
Impedance
60 Ohm
Diaphragm
53 mm
Magnet Material
Neodymium
Microphone
Boom
Electret condenser
Sensitivity
-39 dB
Impedance
2.2 kOhm
Microphone Power Source Voltage (DC)
2 V
Frequency Response
50 - 18000 Hz
2%
Max Sound Pressure
105 dB
Audio Input Details
Cardioid - 50 - 18000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1 m
Carrying pouch, external USB control box, dual-pin airplane adapter
Cable Details
Headset cable - 1 m , Headset extension cable - 2 m
ISO 9001:2008, SGS
Limited warranty - 2 years , Technical support
