HyperX Cloud II Headset
HyperX™ Cloud II features a newly designed USB sound card audio control box that amplifies audio and voice for an optimal Hi-Fi gaming experience, so you can hear what you've been missing. Open up a world of detail other gamers will never know - the rustle of a camper's boot, the scuttle in a distant vent. Its independent audio and microphone volume control lets you adjust not only sound volume but also mic volume and easily toggle Surround Sound 7.1 or the mic sound on and off. This next-generation headset generates virtual 7.1 surround sound with distance and depth to enhance your gaming, movie or music experience. Pinpoint your opponents' location in the game and strike before he sees you coming.
- Advanced USB audio control box with built-in DSP sound card
- Hi-Fi capable with 53mm drivers for supreme audio quality
- Hardware-driven virtual 7.1 surround sound
- Comfortable, 100% memory foam on headband and leatherette cushions
- Pro-Gaming optimized with closed cup design for passive noise cancellation
- Compatible - USB connectivity for PC & Mac. Stereo compatible with PS4, Xbox One1
- HyperX Cloud II - headset
- Product Type
- Headset - wired
- Recommended Use
- Game console, portable electronics, computer
- Pink
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Sound Effects
- 7.1 Channel Virtual Surround Sound
- Audio Specifications
- Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
- Impedance
- 60 Ohm
- Microphone
- Detachable - boom
- Microphone Technology
- Electret condenser
- Controls
- Volume, microphone on/off, surround on/off
- 2-year warranty
- Product Type
- Headset - wired
- 320 g
- Pink
- Body Material
- Memory foam
- Headband Material
- Foam
- Earpad Material
- Leatherette
- Recommended Use
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 15 - 25000 Hz
- Total Harmonic Distortion (THD)
- <2%
- Sensitivity
- 98 dB
- Impedance
- 60 Ohm
- Diaphragm
- 53 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Sensitivity
- -39 dB
- Impedance
- 2.2 kOhm
- Microphone Power Source Voltage (DC)
- 2 V
- 50 - 18000 Hz
- 2%
- Max Sound Pressure
- 105 dB
- Audio Input Details
- Cardioid - 50 - 18000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Cable Length
- 1 m
- Included Accessories
- Carrying pouch, external USB control box, dual-pin airplane adapter
- Cable Details
- Headset cable - 1 m , Headset extension cable - 2 m
- ISO 9001:2008, SGS
- Limited warranty - 2 years , Technical support
