Product
HyperX Cloud II Gaming Headset PC/Mac/PS4/Xbox- Gun Metal
Quicklinx: B40KWS00 Mfr#: KHX-HSCP-GM
Recommended Use: Computer, Game console, Portable electronics
Connectivity: Wired
Earcover : Binaural
More than 50 in stock
£73.06 ex VAT
£87.67 inc VAT
Clarity never felt so comfortable.
HyperX® Cloud II features a redesigned USB sound card audio control box that ampli es audio and voice for an optimal Hi-Fi gaming experience, so you can hear what you've been missing. Open up a world of detail that other gamers will never know -- the rustle of a camper's boot, the scuttle in a distant vent. Its independent audio and microphone volume control lets you adjust not only sound volume but also mic volume and easily toggle Surround Sound 7.1 or the mic sound on and on .This next-generation headset generates virtual 7.1 surround sound with distance and depth to enhance your gaming, movie or music experience. Pinpoint your opponents' location in the game and strike before he sees you coming. It's hardware driven and plug and play, with no driver needed.
HyperX Cloud II has a digitally enhanced, noise-cancelling microphone with automatic gain control functionality and echo cancellation enabled through the USB sound card. The result is clearer voice quality and reduced background noise, with voice volume automatically increasing as in-game sound gets louder, to optimise team communication and in-game chat in intense battles. HyperX Cloud II is certified by TeamSpeak and optimised for Skype and other leading chat programs.
HyperX Cloud II is Hi-Fi capable, with 53mm drivers for superior audio performance and rich sound quality with crystal-clear low, mid and high tones and enhanced bass via the sound card.
Pro-gaming optimised, HyperX Cloud II is USB-powered for PCs and Macs and 3.5mm stereo-compatible for PS4 and Xbox One.1 Its closed-cup design helps with noise cancellation in gaming tournaments and other loud environments so players can obliterate the enemy in peace.
HyperX Cloud II comes in three new colours -- Gun Metal, Pink and Red -- and is covered by a two-year warranty and free technical support.
  • Advanced USB audio control box with built-in DSP sound card
  • 7.1 virtual surround sound
  • Digitally enhanced noise-cancelling microphone
  • Newly designed full USB audio control box
  • Premium sound card enables superior audio
  • 7.1 virtual surround sound control
  • Independent headset and microphone volume control
  • Microphone slide mute
  • Backlit LED
F E AT U R E S / B E N E F I T S
Audio experience -- hardware-driven virtual surround sound
Comfortable -- 100% memory foam on headband and leatherette cushions
Pro-gaming optimised -- closed-cup design for passive noise cancellation
Compatible -- USB connectivity for PC & Mac. Stereo compatible with PS4, Xbox One1 and mobile
Guaranteed -- two-year warranty, free technical support
S P E C I F I C AT I O N S
Headset:
Transducer type
: dynamic Ø 53mm with neodymium magnets
Operating principle: closed
Frequency response: 15Hz-25,000 Hz
Nominal impedance: 60 per system
Nominal SPL: 98±3dB
THD: < 2%
Power handling capacity: 150mW
Sound coupling to the ear: circumaural
Ambient noise attenuation: approx. 20 dBa
Headband pressure: 5N
Weight with microphone and cable: 320g
Cable length and type: 1m + 2m extension
Connection: single mini stereo jack plug (3.5 mm)
Microphone:
> Transducer type: condenser (back electret)
> Operating principle: pressure gradient
> Polar pattern: cardioid
> Power supply: AB powering
> Supply voltage: 2V
> Current consumption: max 0.5 mA
> Nominal impedance: 2.2 k
> Open circuit voltage: at f = 1 kHz: 20 mV / Pa
> Frequency response: 50-18,000 Hz
> THD: 2% at f = 1 kHz
> Max. SPL: 105dB SPL (THD1.0% at 1 KHz)
> Microphone output: -39±3dB
> Length mic boom: 150mm (include gooseneck)
> Capsule diameter: Ø6*5 mm
> Connection: single mini stereo jack plug (3.5mm)
HyperX Cloud II - headset
Headset - wired
Recommended Use
Game console, portable electronics, computer
Gun metal
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
Impedance
60 Ohm
Microphone
Detachable - boom
Microphone Technology
Electret condenser
Controls
Volume, microphone on/off, surround on/off
2 years warranty
Headset
320 g
Gun metal
Body Material
Memory foam
Headband Material
Foam
Earpad Material
Leatherette
Recommended Use
Headphones
Circumaural
Headphones Cup Type
Closed
Dynamic
Wired
Sound Output Mode
Stereo
Sound Effects
Frequency Response
15 - 25000 Hz
Total Harmonic Distortion (THD)
<2%
Sensitivity
98 dB
Impedance
60 Ohm
Diaphragm
53 mm
Magnet Material
Neodymium
Microphone
Boom
Electret condenser
Sensitivity
-39 dB
Impedance
2.2 kOhm
Microphone Power Source Voltage (DC)
2 V
Frequency Response
50 - 18000 Hz
2%
Max Sound Pressure
105 dB
Audio Input Details
Cardioid - 50 - 18000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1 m
Headset cable - 1 m , Headset extension cable - 2 m
Carrying pouch, external USB control box, dual-pin airplane adapter
Limited warranty - 2 years , Technical support
Recommended Use: Game console
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
Brand: HyperX
Price Range Ex VAT: 50 - 100
