Game without pain.
Let your opponents take the blows while you game without pain. HyperX® Cloud cradles your head in a super-soft padded headband, memory foam ear cushions and leatherette-padded cups so that even your late game will be comfortable. It's affordable, so there's no pain in the price either.
Pro-gaming optimised, HyperX Cloud is Hi-Fi capable and delivers intense audio with crystal-clear low, mid and high tones plus enhanced bass eproduction so that you can lose yourself while you win. Plus you'll look sharp while playing, thanks to the unique HyperX design.
- Memory foam ear pads
- 53mm drivers
- Interchangeable ear cups
Pro-Gaming Optimised:
- Closed-cup design for enhanced passive noise cancellation
- Pure Hi-Fi capable
- Detachable mic
- Solid aluminium build
- Braided cable
- Durable travel pouch
F E AT U R E S / B E N E F I T S
Comfortable -- memory foam ear cushions with leatherette-padded headband
Customisable -- switch between leatherette and velour ear cushions for varying sound profiles and feel
Compatible -- with PCs, notebooks, tablets, mobile phones, aeroplane adapters and PS4 consoles
Distinctive -- HyperX branded design in red and black or white and black
Guaranteed -- two-year warranty, free technical support
S P E C I F I C AT I O N S
Headset:
Transducer type: dynamic Ø 53mm
Operating principle: closed
Frequency response: 15Hz-25,000 Hz
Nominal impedance: 60 O per system
Nominal SPL: 98±3dB
T.H.D.: < 2%
Power handling capacity: 150mW
Sound coupling to the ear: circumaural
Ambient noise attenuation: approx. 20 dBa
Headband pressure: 5N
Weight with microphone and cable: 350g
Cable length and type: 1m + 2m extension + 10cm iPhone
Connection: mini stereo jack plug (3.5 mm)
Microphone:
Transducer type: condenser (back electret)
Operating principle: pressure gradient
Polar pattern: cardioid
Power supply: AB powering
Supply voltage: 2V
Current consumption: max 0.5 mA
Nominal impedance: =2.2 kO
Open circuit voltage: at f = 1 kHz: 20 mV / Pa
Frequency response: 100-12,000 Hz
THD: 2% at f = 1 kHz
Max. SPL: 105dB SPL (THD=1.0% at 1 KHz)
Microphone output: -39±3dB
Length mic boom: 150mm (include gooseneck)
Capsule diameter: Ø6*5 mm
Connection: mini stereo jack plug (3.5mm)
Comfortable
Memory foam ear cushions with leatherette-padded headband. -
Customizable
Switch between leatherette and velour ear cushions for varying sound profiles and feel. -
Compatible
With PCs, notebooks, tablets, mobile phones, airplane adapters and PS4 consoles.
- HyperX Cloud - headset
- Product Type
- Headset - wired
- Recommended Use
- Game console, portable electronics, computer
- Black, red
- Headphones Form Factor
- Full size binaural
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
- Microphone
- Detachable - boom
- Microphone Technology
- Electret condenser
- Controls
- Volume
- Product Type
- Headset - wired
- Black, red
- Body Material
- Aluminium, velour
- Earpad Material
- Leather
- Recommended Use
Audio Output
- Headphones Cup Type
- Closed
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 15 - 25000 Hz
- Sensitivity
- 98 dB
- Diaphragm
- 53 mm
- In-Cord Volume Control
Microphone
- Boom
- 100 - 12000 Hz
- Audio Input Details
- Cardioid
Remote Control
- Controls
- Volume
- Connector Type
- Headset (mini-phone 3.5mm)
- Cable Details
- Headset cable
- SGS
