Your basket is empty
Hypertec Memory 2 GB DIMM 240-pin DDR3
Quicklinx: 93RQWS00 Mfr#: HYMDL2802G
Cost Effective
Complete OEM equivalent memory upgrade with guaranteed cost savings without degredation in quality or service. Ideal solution to expand PC life cycle and enhance performance during cost conscious times.
Lifetime Warranty
Hypertec Memory is 100% compatible with the target machines, designed and built to be functionally equivalent to OEM modules; rigorously tested and complete with Lifetime Warranty as well as Direct Replacement Warranty on prior agreement to enhance support efforts.
Technical Support
Coupled with a complete Lifetime Warranty, FREE UK Based Pre & Post Sales/Technical Support is available when needed.
Simplified Support
Easy to use on-line product configurator, instant product information, significant cost savings and improved service.
Flexibility
Above all, we take the time to understand our customer's requirements, our policies and procedures in many circumstances can be shaped to suit an individual user, helping to deliver a bespoke upgrade solution at the designated user's choice.
Hypertec Legacy - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
Dell OptiPlex 780, 780 N-Series, 980; Vostro 230, 230s, 430
2 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Dell OptiPlex 780, 780 N-Series, 980 , Dell Vostro 230, 230s, 430
