Micro USB Connector transfers notes and audio to your computer and recharges your smartpen using a standard cable connection. Microphone capture your meetings or lectures with crisp clear sound. Built in speaker produces rich full sound to play back your recorded audio. Records everything you write and hear (over 200 hours audio).
- Livescribe ECHO Smartpen - voice recorder
- Product Type
- Voice recorder
- 2 cm 15.8 cm
- 36 g
- Display
- OLED - 96 x 18
- Internal Memory
- 2 GB
- Speakers
- 1 x speaker - built-in
- Microphone
- Microphone - built-in - mono
- Interface
- USB 2.0
- Battery
- Rechargeable - lithium
- Product Type
- Voice recorder
- USB Specification Version and Speeds
- USB 2.0
- Interface Supported
- USB 2.0
Audio System
- Internal Memory
- 2 GB
- File System Supported
- 2 GB
- Functions
- Digital voice recorder
Display
- OLED
- Resolution
- 96 x 18
Speaker System
- Speakers
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- Headset (mini-phone 3.5 mm 4-pole) , USB 2.0 (5 pin Micro-USB Type B)
- Battery
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3, Apple MacOS X 10.5.5 or later
- Additional Requirements
- USB port (compatible with 2.0 specification)
- System Requirements Details
- Windows XP/Vista/7 - 600 MHz HD 300 MB , MacOS X 10.5.5 or later - 600 MHz HD 300 MB
- 2 cm
- 15.8 cm
- 36 g
