Product
Brand
Hypertec Livescribe ECHO Smartpen - Voice Recorder
Quicklinx: 93KSWS00 Mfr#: A-LC-09
Micro USB Connector transfers notes and audio to your computer and recharges your smartpen using a standard cable connection. Microphone capture your meetings or lectures with crisp clear sound. Built in speaker produces rich full sound to play back your recorded audio. Records everything you write and hear (over 200 hours audio).
Livescribe ECHO Smartpen - voice recorder
Voice recorder
2 cm 15.8 cm
36 g
Display
OLED - 96 x 18
Internal Memory
2 GB
Speakers
1 x speaker - built-in
Microphone
Microphone - built-in - mono
USB 2.0
Rechargeable - lithium
Voice recorder
USB Specification Version and Speeds
USB 2.0
2 cm
15.8 cm
36 g
Interface Supported
USB 2.0
Audio System
Internal Memory
2 GB
Display
OLED
Resolution
96 x 18
Speaker System
Speakers
Microphone
Microphone Operation Mode
Mono
Connector Type
Headset (mini-phone 3.5 mm 4-pole) , USB 2.0 (5 pin Micro-USB Type B)
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3, Apple MacOS X 10.5.5 or later
Additional Requirements
USB port (compatible with 2.0 specification)
System Requirements Details
Windows XP/Vista/7 - 600 MHz HD 300 MB , MacOS X 10.5.5 or later - 600 MHz HD 300 MB
