Hypertec Hypertec - DDR3 - 4 GB - SO DIMM 204-pin
Quicklinx: B3FJWS00 Mfr#: 0A65723-HY
Hypertec - DDR3 - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for ThinkCentre Edge 72z; ThinkCentre M72z; M92z; ThinkPad Edge E130; E135; E330; E430; E430c; E431; E530; E530c; E531; S430; ThinkPad L430; L530; T430; T430i; T430s; T430si; T430u; T530; T530i; W530; X131e; X230; X230 Tablet; X230i; X230i Tablet
Hypertec - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
IBM 0A65723
4 GB
Upgrade Type
System specific
IBM 0A65723
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
