Hypertec - DDR3 - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered - non-ECC
- Hypertec - DDR3 - 4 GB - DIMM 240-pin
- Product Type
- RAM memory
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Unbuffered
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Chips Organization
- 256 x 8
- Compatible Slots
- 1 x memory - DIMM 240-pin
