Your basket is empty
Hypertec Hyperam 2GB PC2-5300 128X8 DIMM Memory Module
Quicklinx: 93J1WS00 Mfr#: HYU25312882GB
Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hyperam - DDR2 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
8K refresh, dual rank, eight banks, On-Die Termination (ODT), Serial Presence Detect (SPD), unbuffered
Voltage
1.8 V
Lead Plating
Gold
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Module Configuration
256 x 64
Chips Organization
128 x 8
Voltage
1.8 V
Lead Plating
Gold
RoHS, Lead-Free
