Hypertec - DDR3 - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - 1.35 V - registered - ECC - for Dell PowerEdge C8220, R320, T320; Precision T5500, T7500
- Hypertec - DDR3 - module - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Dual rank, Low Voltage, registered
- Voltage
- 1.35 V
- OEM Manufacturer Equivalent Part Number
- DELL A6996808
- Limited lifetime warranty
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DELL A6996808
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Voltage
- 1.35 V
