Hypertec - DDR3 - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for Lenovo ThinkCentre M92; M93; ThinkPad Edge E43X; E53X; ThinkPad T430; X131e Chromebook
- Hypertec - DDR3 - module - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- IBM 0A65724
- Limited lifetime warranty
- Capacity
- 8 GB
- Upgrade Type
- System specific
- IBM 0A65724
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Non-ECC
- Unbuffered
