Hypertec 8GB SODIMM 204-pin DDR3 Memory Module
Quicklinx: 93K6WS00 Mfr#: 0A65724-HY
Hypertec - DDR3 - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for Lenovo ThinkCentre M92; M93; ThinkPad Edge E43X; E53X; ThinkPad T430; X131e Chromebook
Hypertec - DDR3 - module - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
IBM 0A65724
8 GB
Upgrade Type
System specific
IBM 0A65724
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
