- Hypertec - DDR3 - module - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- HP NL797AA
- Limited lifetime warranty
- Designed For
- HP Workstation z200, z400, z600, z800; HPE ProLiant ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server
- Capacity
- 4 GB
- Upgrade Type
- System specific
- HP NL797AA
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HP Workstation z200, z400, z600, z800 , HPE ProLiant ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server
